DRZ-400S to SICK-SM build
That valve cover looks sick!
Thanks bro! :bonk:
sick build dude keep up the good work!
Thanks! Will do!
A little mid-morning progress, got the Unabiker radiator guards on and the MotoHose radiator hoses. I'm gonna start on the remaining vent hoses shortly, and will update later this evening.
Thanks! It wasn't hard at all but I pulled the radiators completely off since I was doing the hoses at the same time.
Got the rest of the red silicone vent hoses installed, did the initial 500mi service, installed engine ice and flushed the radiators of all previous coolant,installed the Profilter billet oil filter cover and the SDG step seat.
However, I didn't have enough time to get my LightSpeed carbon engine guards and skidplate back on before going out to dinner.
Tommorow I'll knock out the Pro-Taper Metal Mulisha 1-1/8 bars, Zeta Armor handguards, Zeta stem nut/cap, bar mirrors, grips, bar end sliders, key relocation,powdercoated cfc case savers, MSR +1 shifter and do the axle sliders.
Edited by atsownz
Ah! I couldn't walk by the garage and not put the carbon engine guards and skid plate on. So I threw them on real quick! More progress tomorrow!
Edited by atsownz
Well, made a little bit of progress to wrap up the weekend. I got the Pro-Taper bar adapters, Metal Mulisha bars, Zeta bar clamps, ignition key relocation and the left side Zeta armor hand guards with led turn signal protectors done. The right side Zeta hand guard was bent wrong at the factory not allowing it to be mounted flush with the bar end and thus pushing everything into mis-alignment. I ended up calling Forrest at Wheeling Cycle Supply, and he was more than accommodating by sending out a replacement today.
So once the replacement right hand guard arrives and I get some free time, I will wrap up the right side of the bars, install the stem nut/cap, re-bend the MSR shifter, CFC case guards, bar mirrors, and knock out the axle sliders.
Things definitely took longer than expected and put me behind due to parts not fitting etc. I plan on installing the Ebc 320mm rotor, Ebc mxs pads, and Hel stainless lines once i get my wheels from Rad Mfg. That way I can knock it out all at the same time. I will be ordering a MRD/SSW exhaust shortly along with a couple of other small things , getting a few more parts powder coated, and figuring out a graphics setup.
Stay tuned in the coming days and weeks for updates when parts arrive and some more install time! I've attached some pics of the progress made today. Disregard the loose wires, as I didn't see the need in zip-tying everything together until I receive the replacement right hand guard and finish up the whole install. :bonk:
Edited by atsownz
And here are a couple of pics of the whole bike. :bonk:
Edited by atsownz
Update!!!
Just got off the phone with Dave at MRD Racing and placed an order for a 12" shorty SSW pipe with a carbon fiber endcap. I plan on giving Eddie a call on the first of the month an placing an order for a FCR 39mm carb kit.
Stay tuned! :bonk:
Edited by atsownz
good stuff
im in progress of a similar supermoto build
bike was a 2000 drz400s so it was blue and white oem i road dirt only for 2 years thats why it so dirty compaired to your pics
paited and powder coated tank and rims and hub and decal kit from AMRracing.com
it has so far a 434 bigbore kit ,3x3 air box mod, 25pilot jet 142.5 main extended fuel screw on stock carb. might get FCR carb but its pricey, im gonna order the MRD/SSW exhust asap then hotcams, etc
im gonna put $$ into performance and hp to unlock drz400s full potenial before i put money into accesoriess
IMG_1208.jpgif u noticed my rad is bent way outa shape...bike sliped off stand and hit it, brand new rad too
but if your like me and tried to hill climb and ride dirt drz400 wieghts 313lbs dry its a heavy machines for my likeing so im converting to street.and get a dirt bike. i might sell this when im done and get a KTM 530 its 247lbs dry plus
Looks like its going to be sweet !!!!!!!!! i got 2 questions for you how do you like that seat is it same hight as stock? And what knid of rear turn signals are those? They look good that is what I need......
Thanks! I love the seat! The part that is "grooved" where you sit while riding is the same height as stock, and the rear portion is obvious a tad bit higher due to the step up. The seat really keeps you locked in while riding hard and gives a little bit of rider security by holding you in place. The turn signals are the "601" style in smoke, and I got them and the seat from Forrest at Wheeling Cycle Supply.
Any pics with installed mirrors. I'm just missing the mirrors and I'm good to go. Still undecided between you bought or the CRGs.
I haven't had a chance to get them mounted, as I'm still trying to figure where on the bar I'm going to run them. But you can't go wrong with the ones I bought. Excellent quality and a great price.
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
