2011 Yz 450 set up and tuning
Hi all, the rings in the pic for the fork spring preload, has anyone tesetd them at the top setting ? Did you use a stiffer spring due to less preload ?
For instance if I used a .48 on the top setting instead of the stock .47 preloaded on the bottom setting? The application is for off road racing/ cross country,
Also, I have a spare set of 2009 yz 250 2t forks which I want to use to test different shimstacks, but If i remember they are 20mm shorter than the 11' 450? Would this be a problem ?
Lastly, just a question on the metal free pistons, will they have the same preload on the ics spring as the plastic units ?
Thanks for the replies
