02 XR400 Subframe needs welding?
I need to weld my subframe where the cross member under the seat pan meets the piece that the pan/fender bolts to.
Anything I should bulk up while I'm in there welding?
I would suggest NOT using an arc welder. Do mig wire welder. Arc has a tendency to blow right thru an XRs frame tubing and you end up with a bigger problem.
You might look at the area you're welding to see if it would benefit from gussetting.
