Valve Clearance?
I'm getting ready to check the valves on my 09 and after looking up the tolerances I'm mixed up.
The tolerances listed on Team Green's website are,
intake- .17 - .22 mm
exhaust- .10 - .15 mm
I also searched some threads on here and found the same numbers, but switched. (intake .10 - .15 mm and exhaust .17 - .22mm)
Can anyone set me straight on this?
Not sure were your seeing that. Team green says this:
intake i know is always the tighter spec
Intake - (.004 to .006) or metric (.17 to .22)
Exhaust - (.007 to .009) or metric (.1 to .15)
Edited by spin05
Both are wrong.
The intake is .10 - .15 mm
The exhaust is .17 - .22 mm
I'm 100% certain. The Team Green instructions have the info mixed up.
Both are wrong.
Yes you are correct .Atleast as far as the Millimeter callout. The u.s. inch callout is correct. I use that anyway. So didnt notice the millimeter being reversed.
