honda axle bolt?
I got a crf 450 r (2009) Honda axle bolt and when I thread it by hand it doesn't want to go on all the way. At first, it fits perfect, but it gets about 3/4 of the way onto the axle and comes to a dead stop before getting to the end. Once that happened, I didn't want to attempt to crank it on, so I stopped to make sure I had the right bolt. honda part number is 90305-kz4-j20. when i compared it to the castle nut, it doesn't look as deep.
does anyone know if I have the right bolt??
The Honda bolt is a nylock, you are hitting the part of the bolt with the nylon in it that locks it in place. It's normal, and it's the reason you don't have to use a cotter pin with it.
I took my stock nut from my Honda and threw it as far as i could. That locking mechanicsm has a habbit of seizing on the threads and stripping the nut out. I went and bought a KX450 rear nut and threaded it on to my stock axle. I just drilled a hole in the axle and istalled a cotter pin. In my opinion the Kawasaki nut is a much more reliable design.
I would put some anti seize on there before you put the nut on in order to prevent it from gawling your threads.
....and it's a nut, not a bolt.
Lol. Right. Nut, not bolt.
The nyloc is nice but the cotter pin really only takes another 30 seconds to deal with so it's really not that big of a deal. Plus you are only supposed to use a nyloc so many times before it is supposed to be replaced. At least that's how it is in aviation. Actually in aviation I think your only supposed to use it once...
Edited by shang
On a dirtbike a nyloc nut is fine to re-use as long as resistance is felt when the thread reaches the nylon plastic. Ny-loc = nylon lock.
A Fuji locking nut does the same thing, but the last thread in the nut is of a different pitch to make it grab on to the thread and not back out.
A castle nut uses a cotter pin through it´s slots, through a hole in the axle/bolt.
Another common type of nut is the toplock nut that has deformed threads at the end to achieve the same thing.
A castle nut, or a nyloc, are basically the only ones that does not wear the thread out and causes seized bolts with repeated use.
Edited by D-K
okay, thanks for the info, just wanted to make sure before i crank it on. and yes, my BOLT is definitely a NUT, haha.
I really don't care about dealing with the cotter pin, but I went to buy some (at a Kawasawki Dealer) and they wanted $2.00 a piece!! The Honda nut was $7.00 so I figured I might as well just use it instead. Does anyone know where to get the cotter pins at a reasonable price? I'm sure I could get something comparable without buying the ones from Kawasawki, but my bike didn't come with one, so I don't have a reference.
Honestly, if you use a torque wrench and are 100% certain that you reach 110 Nm of torque, you don´t need the cotter pin at all.
In all my years of riding, I have never found the nut wanting to back off and be resting on the cotter pin. If the nut is tight, it won´t come off.
And if it´s price, or convenience, you can put just about anything in the hole. A zip-tie, a nail, anything to be on the safe side.
The cotter pin is most likely a lawyer suggested part, since many other bikes have no locking feature on the rear axle nut (KTM).
Yeah, I'm not gonna lose any sleep over it. Thanks for the info!
you can buy the cotter pin at your local hardware store for 10 cents. I bought an assortment a long time ago for something like 20 dollars and It has all diffrent sizes for what ever I am working on.
