2004 CRF250R
I was wondering how I could loosen up my clutch so that the lever would pull easier. Also I would like to make my throttle easier to turn. Thanks for reading, I could really use some help.
Replacing the cables works wonders. Aluminum throttle tube with bearing. You could also extend your clutch actuator arm by 5mm. That significantly reduces the pull. Can't go more than 5mm.
