front sprocket question
I just replaced my front sprocket on my 95 xr650l. I noticed there is a little play from side to side. Not much but maybe 1/32 or less. :smirk: But it was enough to ask the question. I seem to remember that there was a little play when taking it off. Please advise. Than you
Yup.............normal,,,,but you an use a XR650R sprocket on the front,,put it on backwards and it fits,and is thicker at the splines which spreads the load out and slows/stops countershaft wear and fits tighter because of the extra thickness at the splines....do a search,Spud has a thread here on this ..
B
Yes it is normal however I don't like it so what I did is applied blue loctite to the spline shaft and the new sprocket let it sit over night and its rock solid in the morning your good to go.
