08 rm85 not top end power
my son was riding his rm85 yesterday then came to me saying it
doesn't rev like it used to but idles fine.i pulled the plug and found
it was fouled so i put a new one in and got the same results cleaned
the carb didn't help.
i'm new to 2 strokes and don't know where to go next.
thanks Brian
Edited by docholaday67
the only thing i didn't check was the reed valves. i would assume
they are between the carb and the cylinder.i have also read on
here that the power valve may be the problem but know nothing
about them. is the power valve located just above the header pipe?
Power valve could be carbon up and sticking, or the only other thing that can happen is the bolt (behind the right cover, will need to remove the pipe to get to the cover) has back out and the linkage has came loose.
A realy dirty air filter is the number one cause that will kill the RM85 top end power also.
The bike will not run correctly with out the air filter or the silencer.
If she is starting and running, then chasing the wiring won't help your problem.
Do check the power valve system for loose linkage bolt and carbon up power valve.
May just need some fine tuning on the jetting to get it running clean in the winter weather.
