Honda 87 250X
I have an oil leak on my 87250X and I need some help fixing it.
There is a hose above the cylinder head, tucked under the frame and that is where it leaks from.
Any suggestions?
Thanks
where on the engine does the hose come out of? it sounds like it may be a breather hose and that could be bad if its forcing alot of oil out of it, the hose normally runs into the airbox. if it is the breather hose that oil is coming out of it could be time for a top end rebuild with a piston and rings + overbore.
