Oil Leaking from Water-Pump Cover? (200EXC - 2000)
I removed my skid plate and cleaned my engine really well to try and find where my oil leak is. It really looks like it is leaking from the waterpump cover. How can this be? I thought there was only coolant under there. No coolant leaking, and no coolant and oil mixing that I can see. Bike is a KTM 200 EXC year=2000.
A friend said it is the WP shaft seal, but I don't understand how that would leak oil and not coolant.
I plan to drain coolant and remove cover to verify, but I'd like to know what parts I might need to order before doing this. If it is the WP shaft seal, do I need to remove the whole side cover to change, of just the WP housing?
My 2001 KTM 200 EXC is doing the exact same thing, were you able to figure out what the fix is?
