How to remove chrome/nickel plating on pipe?
I like that factory look as well. Does have a downside though. Rust. You have to keep it clean & moisture free or it will look like crap. I clean mine after every ride & put some wd40 on a rag & wiper er down. It does burn off next time you run your bike & may smell a bit & smoke a bit as well if you apply to much wd. Its worth the extra effort to me for the look I like. I stripped mine over a year ago & it still looks great. I used a stiff wire wheel & electric drill (took hours & sore hands) after treating it will a aircraft type stripper available at most auto parts stores.
Couldn't you just sandblast it? Simple and cheap. In fact, the local machine shop let's me sandblast for free, but I always throw them $10 or $20.
Stripping the plating will cost nearly as much as just buying an unplated pipe.
Sandblasting won't remove the plating, it will just make it look like crap.
if i wire brush the paint off of a stock pipe would it look like the raw factory pipe?
No, it will have all the scratches from the wire brush, and crappy looking welds.
