max. safe advance 2012
do anybody know what the max. save ign. advance is for the 2012 crf 250 . at full throttle. how mutch degree,s on the rotor
Edited by speedboot
if your making hp above 13000 rpm you cant put enogh timing in from the stock unit the system only alows 4 degrees stock bikes seem to like a couple of degress after peak torque ocurs but thats on the dyno and may not be showing maximum load.
thanks , i can go to 12 degrees retard on all fields , so when i advance the pick up a few degrees i gan always retard it on the others field to compensate . when i advance the pick up 4 degrees and with the 4 from the program i have 8 total extra advance above stock setting
Edited by speedboot
