How do I make my front brake softer?
My front brake on my crf250r 2005 is way to hard for my preference if I pull it the front wheel just snaps instantly, how do I make it softer? any kind of help is apreciated :smirk:
Spray WD-40 on the brake disc!!! Joking....
You can adjust you brake lever, there should be a screw on the lever that you should be able to back out.
Why do you think they are to powerful? Modulation is key to good braking technique. Many people would kill to have good strong brakes.
I don't know I guess that I have had to little freeplay then :bonk: will go down to the garage and fix it and see if it helps. Thanks dude ! :smirk:
In my experience Hondas just have really strong brakes. If you look around the YZ forum the hot thing is to swap out the YZ brakes for CRF.
Lol, tell this to MXA they have hondas brakes last in the shootouts. I find that totally off point! as per usual!
