2006 TRX450R Bog when punching throttle
I have a 2006 TRX450R with no upgrades. It is boggy if you punch the throttle, Already had the carb off and went through and cleaned it but is there any other suggestions? Also already had the valves adjusted.
Edited by LegitWhiteBoy17
Have you adjusted your fuel screw? My 400ex would bog for a second and then eventually go. It primarily did this in first and second gear. I adjusted the fuel screw was it runs perfect.
