Drz 490 new clutch choice
Anybody out there have any recommendation as to what is a really good heavy duty clutch to use on a drz with a 97mm bore and a 4mm stroker crank. Basically a clutch that good for high hp thumpers, I was running a kx 500 clutch plates in it before but as I've gotten coolant in the oil and in the process of doing that repair I would like to replace the plate as they have been contaminated.
Thanks
Kevin
OEM drive disks, clean un glazed OEM driven steels, works great. Add a set of higher pressure springs if you feel the need.
If you clutch started slipping with that leve of build, it was worn already, and the extra HP / TQ just showed the flaw.
