XR600 airfilter that come with a new cage?
Uni foam filter comes with a nylon and coarse wire mesh screen. You can also just buy the foam element.
Moose foam only
twin air foam only I beleive
K/N is stand alone
I have a dt-1 element and uni foam filter that I switch between. I have decided for jetting purposes that the stock screen.mesh cage and either of these foam elements provide consistent throttle and power.
Even over the uni cage.
Price for uni with cage is around 35-45bucks. I bought mine on ebay.
Scott summers(if your doing your replica) reccomended keeping the stock cage/mesh screen and a good foam filter with possible a prefilter sock in dry dirty conditions.
Hope this helps,
cheers
I cut out the backfire screen on my 600r and have regretted it every since. Even though it gained on the mid and top, it lost some of that legendary low end throttle response.
Let us know what you find in your search..
Yep reconfirmation. THanks all.
I ended up emailing a bunch of ebay sellers as well before you posed above. It was confirmed that UNI is the only one with a cage. The stock cage I have already has the mesh screen cut out. bummer. Which I could find a stock cage. Anyone have one....?
