Cylinder Service Limit vs Cylinder specs
The 05 CR250 OEM service manual says:
Under Specifications:
(A) Cylinder I.D." 2.6141 - 2.6244
Under servicing:
Use the largest measurement to determine the cylinder wear (Top,Middle,Bottom...)
Service Limit: (A) Cylinder " 2.615
So how can the service limit not only fall inside the stated cylinder spec but its at the smaller end not the larger end of the spec? - that is where I would expect it. like ("Service Limit" greater than 2.625")
Am I missing something?
Edited by AXAxiom
