07 KX250F Leaking water
Guys pls help... My buddy 07 KX250F is leaking from the small hole on the right hand side of the cylinder. Pls see the attached pic. What is wrong and what need to Be done?
I suspect that it is just water and dirt that has been pushed up in there from washing the bike.
You can remove the fuel tank and the spark plug cap/coil and make sure the spark plug well and the drain hole is clean and dry.
If that does not help, the cylinder head is cracked and needs replacement.
Edited by D-K
Thanks guys problem solved it's the dirt and water from washing the bike. Just check it and it is dry up and no more seeping of water already.
