Yamaha YZ 250 1998 Rebuild
This will be my first rebuild and hopefully everything goes to plan. Brought the bike last year May its my first mx bike :bonk: still completely standard. From the beginning the bike will foul 2 plugs every hour. Fitted a new wossner piston and still did the same found out it was my crank seals. So I figured if im going to split the case I can just aswell do a complete rebuild of the bike. My shopping list so far is: Powder coat the frame, chain and sprokets, new footpegs, spraying the motor, tyers, bearing and seals etc. Here is a few pics of the bike
When I brought the bike
My piston with only 2 hours on it :smirk: running too rich ? Current jetting Main 170 pilot 48 needle clip 2nd Running 1:40 air screw 2 1/2 turns out and my altitude is at sea level .
My reed valve with no stoppers is this normal ?
Worn power valve stopper
Think my power valve is well matched with my barrel??
Head carbon at exhaust port side
Where my power valve started touching my piston
Current state of my bike
Will hopefully get the project done by the end of march.
Great photos. I'm glad you posted the pv rubbing the piston pic. YThis will be good to show others who wonder what it looks like.
RCannon
What do you think I should do? tap a screw in the powervalve stopper or use steel putty on the worn part? How much do I need to file my power valve?
Nice looking bike! Good luck on your project, make sure to give us lots of picture!
Small update on the project. Progress is slow at the moument between my work and studies. New parts arrived today
FMF powercore2 and main bearings
Is there a reason why the clutch side main bearing looks like this ?
Crack in my frame :bonk: will get it welded up this weekend
Is my frame bent?
Bent subframe will sort it out this weekend
My shopping list just gets longer and longer by the day lol guess thats the way these projects go
