DR-100 valve adjust / cam chain adjust
Hi, all!
I recently picked up a 1989 DR-100 and got it running, fixed the brakes, replaced the cables, etc.
Anyway, it runs, but the valves are a little noisy. I didn't get a shop manual with it. Wondering, does anyone have a shop manual for the DR-100 -- could you give me the specifics on adjusting the valves and the cam chain tensioner? Thanks!
Russ
im searching for ya, but im having about as much luck finding your specs as i did finding mine, but have faith, this is the best cycle talk websit on the net, someone will find it for you :smirk:
Thanks.
Is the cam chain adjuster semi-automatic? On my Z-50, you just loosen the lock nut, loosen the holding screw, then re-tighten, and it automatically adjusts the cam chain tension. Does the DR work the same way?
Russ
