Kayaba Fork Rebound Needle Removal
Got a 2011 Husky te310 that I'm changing the fork oil in. While I have the forks apart I wanted to grease the rebound needles(to prevent seizing up). I have done this on my KTM, the needle popped right out by sticking a thin straight object thru the midvalve.
I tried this on my Kayaba and the needle doesn't want to pop out. I did not want to put undue force on it, so my question is, does this needle pop out or do a I need to break down the midvalve to get at it which I'm not willing to do. And yes when apply pressure to the rebound rod I can feel the spring tension so it is not siezed up.
I can't find alot of information on these forks on the internet so I'm kind of flying in the dark.
Edited by RailwayRog
You don't need to worry about that with the KYB forks. But yes, you would have to remove the rebound assembly to remove the adjuster needle.
