Sunk for days!
Had a bad day on the ice! Need advise on what to do once pulled out! Will drain all fluids clean carb and filters. Should I do anything be for starting? Will it ever be the same? Thanks for any input!
If you want to do it right, a complete teardown is called for with a complete drying of all parts. I had a bike in a basement that got flooded and then froze. The bike was there for three months. No damage. Just took a few days to take every single thing apart (that means take apart the master cyl, too for the front and back brakes as well as the entire engine and forks, pull wheel bearing ECT..) Be sure to remove the wiring harness and hang it in a hot dry place to allow water to drain and dry out.
Bikes out , drained and drying! Took 20 minutes for two of us to pull it out. Had it striped down and drained 20 minutes later. Will get back at it tonight ! Thanks for input!
