How to adjust XR250L Accelerator Pump
I think I have finally found the problem on my bike lean issue. The XRLs are only equipped with accelerator pumps to rid of low end hesitation. From what I understand, they work great, when they work. Now when it appears as it is not working (in my case) the engine hesitates extremely and is very annoying. So if you take a look at the picture and video, I need to increase the amount the needle is being pushed down at idle.
Video:
http://www.youtube.com/watch?v=ekhMm-jiap0&feature=youtu.be
I will have better picture when I pull the carb off.
Edited by codyp1814
Yes the 250L carb is very poorly jetted (RESTRICTED), Way too lean, Not good for your motor too
+1, Shorten the spring
DONT bend the tab, That just gives you less pump travel
If you want to jet your carby much closer to XR250R specs use the Keyster KH-0831 kit and it includes all you will need, Took me a lot of stuffin round to work it all out but its guaranteed
You can search ebay or online shops or (google) Keyster KH-0831
This is where I got my kit here in OZ>
http://www.motorcycl...and-parts-kit-1
I used to need the choke to start it and even then it did not start very easy
This is how it runs now, NOTE: there seems to be an Audio delay in the video, Listen rather than watch>
This is a bit more detail on how I worked it all out, Hope this helps>
http://www.thumperta..._1#entry9785675
Edited by XR250INOZ
