SFF Spring Change - Homemade Spring Compressor
I made this for about $15 in parts from hardware store. Worked really well. The hole size for the top piece is 1.25", and I drilled it with a forstner bit. Maybe there is another way to do this, but I could not hold down the spring far enough with my hand to get at the rod nut, so this was necessary. I went to 0.95 kg/mm, which is in between the '11 and '12 rates. Race Tech spring. I put a 5.3 kg/mm on the shock, which is also in between. Factory Conn had the 5.3 rate shock spring.
