05 CRF450R stalling when clutch is in and lock the rear brake
When my bike is on the stand (warm) I will shift into first gear and let the chain spin. Sometimes when I tap the rear brake (clutch fully in) it decides to stall. I have stock jetting with the fuel screw 2 1/4 out (sea level/ orlando fl) too rich??
I have the fear of hitting a big jump and stalling mid flight if I tap the rear brake.
clutch is sticking. change the tranny fluid, but before you refill it remove the side cover, the pressure plate and remove all the plates. Seperate them, clean them, reoil them and reinstall. Replace if needed and also inspect the basket to see if it is notched.
When I reassemble the pressure plate, do the six bolts that hold the springs have to be a certain torque. I do not have a good torque wrench for low torque applications. example 0-20 ft lbs
