Broken front axle clamp bolt
Are the front axle clamp bolts on the lower right fork pressed or threaded in?
I broke one of the lower ones the other day and didnt know if i should try to extract it or clean it up and weld a threaded extension to it. Theres about 1/2 inch of stud (it snapped flush with the axle block) so i think there will be plenty of bolt remaining to fix. Thanks
