Fork question
01ktm 400 exc wp43 forks. Are they cartridge? When I remove the bolt from the bottom of the fork leg , should the rod be attached to it or should it come right out?
yes, cartridge style forks.
The rod stays in the cart since the springguide/hydrostop hold it there.
If you remove the cart from the outa tubes and put the springguide off, you can remove the rod from the cart.
