Will Hotcam stage 2 cam work with Kibblewhite springs?
i just bought a hot cams stage 2, and just started thinking about how much pressure the kibblewhite springs have.....i noticed in particular that they have 2 springs per 1 valve, one inner and one outer. will the combination of the springs and the new cam cause too much friction between the valve buckets and the lobes on the cam causing damage? I'm thinking either the lobe or the bucket will have excessive wear or even worse damage. i don't think excessive damage is going to be the problem, I'm just thinking about the amount of friction that the lobes will be under. need some experts opinions, what do you guys think?
Thanks, -Aaron # 087
