05 450 Trans fluid
Ok so the past year i have been using Lucas ATF semi synth in my tranny well what do u guys run should i change it to somthing else or should i be good running it i uses it in all my 2ts and im getting it at like under 5 bucks a quart should I be using hondas 80w gearlube or w.e it is?
THAT'S fer sure. For me, unless I am having to change it often, I use GEAR oil in GEARS. Ford ATF-F is a viable choice too, but aint as cheap, and some trannys shift notchy when using it.
