Widest rear tire that will fit on stock 03 crf450?
Why widest? That's not always best. A 160 will fit on a 5" rim and a 150 is best on a 4.25-5. You want to match the tire to the rim that you have. Otherwise you'll throw off the handling and the life of the tire.
what do you do with the bike? street riding? if so stick with either a 150 or maybe a 160 on a 4.25. The 150 should be fine with no rub assuming you have a chain guide. 160 will probably get some rub even with a guide.
Different tires have different widths too. I went from 160/60/17 Pirreli slicks which didnt rub at all to 160/60/17 Qualifiers that rubbed on the chain and had less than 1/8" clearance on the swingarm; then back to 160/60/17 Power Pures that again fit with no rubbing. BTW highly recommend the pures for street. these were on my XR650R, im sure the swingarm is close to the same width.
