Rattling instrument cluster
Had a steadily increasing rattling noise coming from my front end, I first suspected the speedo assembly in the front wheel. Turns out it was just the plastic light cover on my instrument panel. Other than running a bead of super glue around the base, (Or getting a different setup) is there anything that can be done to make sure it stays quiet? I was going to run a zip tie around the outside of the entire cluster to help absorb the vibrations. Also just seeing if anyone else has had this problem.
I think if you look up there you will find there is a little metal bracket that clicks around. It looks like coat hanger wire, its not connected to anything except your cables. Basically, it keeps them straight when you turn the bars. I covered mine with duct tape so its quiet, others remove it altogether. Make sure if you remove it you use some loose zip ties to keep those cables in place but not restricted.
