need identification help quick. gotta order parts (pics now
a buddy of mine has an 04 yz250 frame with an older engine on it. i need help to know what year it is. i have to order some trans parts for it. here are the numbers i found on it. first is SP 005869. the others are 2VM06. here are some pics of the motor if it helps. thanks
Edited by ridinredneck
it has to be newer than 04 based on that number you provided. Ive found every engine id # from 74'-04' and it hasnt showed up. cant find anything newer.
Google what i did above. Oem cycle has a yz250 identifier that lists a TON of crossover parts/years. I cant post the link bc it says the administrators are blocking it
According to that site it says an 88 trans fits 88-90 and 92 gears fit 88-93. Id confirm it but its a good starting point
Edited by dbart250
