Clutch Problem!
OK im on putting my bike back together and iv just linked the clutch cable back onto the engine and there the leaver is slack. it pulls in but will not pull itself back out. i need help?
Did you have the clutch apart? Maybe yiou forgot something.
Was the arm off the shaft? if so, you likely did not rotate the shaft correctly prior to installing the arm.
I literally wrote this one for this exact issue a member was having
How is the clutch itself activated?
Also have a look at
Clutch Maintenance and Inspection
http://www.thumpertalk.com/topic/569655-clutch-maintenance-and-inspection/
Software is screwing up the link... so just go to the FAQ and find the article if interested.
ok guys i got it sorted :bonk: just me being dence. you were right i dint turn the clutch spine the right way before locating the leaver. many thanks
