New Jetting for Lowered Squish Band
This is a repost from the YZ Section.
I recently had my stock '05 YZ250 head done by RB Designs. He lowered the squish band to run on premium pump fuel. The mod was a great improvement in the way the engine ran. The motor sings now like a super clean running 125.
Since the mod, the spark plug is showing even richer than the "normal" wet YZ plug (??). I feel I need to lean the jetting out somewhere but the bike runs great and I cannot figure out where the motor is running rich. I will admit I am too lazy to spend half a day (a whole day for me) running the bike and pulling plugs on the trail, blah, blah.
I found a great thread here on how to jet properly, and I will do that if need be. But, if the fix is easy I'd rather keep the day and make the fix.
If anyone has a similar set up, or has some applicable jetting advice for the situation, I would surely appreciate it.
Senior A Rider, Harescrambles, Cross Country, Enduro
Single track to wide open fire trails at Hollister Hills and other parts of CA.
Stock: carb, jetting, cylinder, pipe
squish band lowered to still run on pump gas
filter skins on stock, and Uni air filter, Belray filter oil from bottle
FMF Turbine 2
91 Pump gas, Golden Spectro at 40:1, 1/2 ounce of octane boost per gallon
