PICS: The new "2013" pre factory motor !
Martin Honda debuts the new 2013 motor this weekend in the international Mantova Starcross in Italy. Also debuting with the new SHOWA Air fork ! :bonk:
  • Like 2
Looks pretty cool. Is there some benefit for the longer around the frame exhaust? I'm guessin there is since they've been doin it for a few years now.
just the SFF fork like the KX250F. There was pics of that same setup a few months ago from one of the online mags.
I do not understand the exhaust running under the efi? Why? Looks to me there will be problems akin to the Husaberg. I cannot believe the possible benefit can be greater than the already discovered negatives of the high heat in that area. Those little add on winglets tell me they are trying to improve airflow to alleviate the problem.
Edited by YHGEORGE
thats a heat shield.
Bad ideas as I see them:
1. Exhaust running underneath the EFI and Shock
2. Exhaust running directly over the hydraulic clutch slave
3. "Air" suspension of any kind
4. SFF
5. Bringing any of that to a US market place.
  • Like 2
4. SFF
Not to mention that fact that if you had a manual cam chain tensioner on there it would be a pita to adjust.
This months MXA has a piece on the air forks, claim to drop 2lbs off the front end.....look at the triple clamps.....almost no offset
Possible issue, although many older EFI inline engines had the exhaust manifold pretty much touching the injectors without much issue. Heatshield shouold keep temps down.
Brake fluid boils at ~450-500*F. The rubber cap on the slave would begin to melt way before that - the heatshield is doing its job. The wires running right near the exhaust also proves this to be a non-issue.
Don't see why this is an inherent problem?
4. SFF
Have not heard any complaints about the SFF on the KX250F. Theoretically cheaper to respring and revalve, and you get a pre-load setting now.
Not seeing it as an issue at all as long as the price is right.
No way those little add on plastic pieces at the bottom of the radiator shrouds are a heat shield. Nothing hot there to shield. We must be looking at two different things. And many with other brand bikes using an exhaust routing like this have suffered severe heat related problems. Boiling of the fuel has been a major issue. Maintenance , especially when hot, is very difficult if possible at all in this area. But my main point is that NO ONE has/can provide evidence of any BENEFIT with this routing. None. Where is the reward?
Edited by YHGEORGE
Tell ya what, save my post as a word doc. In August of 2013 if they deliver that setup to the US check it against the complaints lodged against the new configuration. If I'm wrong, I'll buy you a beer. A good beer, not some cheap crap :bonk:
How do we know this is not a 250?
The exhaust port and gen cover is more 250 like than 450.
just asking.
"Air" forks have been done before. They didn't work then and probably won't work now. The problem is heat expansion. As the air heats up inside the fork tube, it expands, effectively increasing the spring rate.
The benefit would be increased length and volume in the exhaust system.
I doubt that outweighs the negatives, though.
just asking.
Bike belongs to GP rider Evegny Bobryshev, competing on the factory Honda 450. Martin Honda only field 450´s this season.
Where are these pictures comming from? Are they taken live or from another media source?
THere's some really nice stuff there.
