CR80 leaking from the telltale hole underneath the waterpump..NEED HELP
I don't know if it is leaking oil or coolant but the coolant level is still the same and it looks kinda like a red-ish color, take a look at the video please...Any help is apreciated such as what it costs to fix it etc. // mike p.s I noticed it after changing the gear oil..btw it starts up on the first kick and runs perfect.
http://www.youtube.com/watch?v=UbPdxIIylVs
first off wash the bike so that you can see where it is leaking from better. Get some engine block cleaner, scrub and pressure wash.
The hole is the weep hole for the water pump. Doubt that is where the fluid it coming from, but could. I would suspect a bad crush washer on the drain bolt for the base.
again, clean it! You have so much dirt and grime on there, it will be hard to tell where its coming from with it so dirty
