Brake Hose Length. Sm/S/E
ok guys iv been looking all over the place to find some details on hose lengths. i plan on changing the front and rear brake on my drz400e. im planning on buying some new stainless braided lines made by Hel. any good? but on his shop he only sells them for S/Sm and no E i took some measurement and got back to him with them and he sent me this back.
Hi, I’ve had a look into your enquiry, the nearest to your bike is the DR-Z400S (2004-2005) front 1400mm rear 615mm
The spec’s are showing as follows:
Upper front 20 dgree bend with a 20 degree right bend on the banjo the caliper end has a straight 20 degree bend on the banjo, the nylon is 750mm long.
Upper rear has a straight banjo, the caliper end has a 20 degree bend with a 20 degree right bend on the banjo.
I measured 1300 for front from the inside of the banjos and its around the 1400 to the tips of them. rear was 560 to inside and 660 from tips of them. but im not sure on the correct degree. could any one help me out?
