Specific parts interchangable between years?
I am rebuilding an 04' I picked up for $800. I also have an 09' that I will be using old parts from as well as newer parts on ebay etc. This info will really help.
Will an 04' valvetrain fit into an 08' head?
Would 09' intake valves fit into an 04' head?
Would a full 09' exhaust (aftermarket single muffler) fit on an 04'?
Would an 09' header fit an 04' with an 04' muffler?
Is the newer year linkages different? If so, what years would fit the 04'?
Edited by stocktires
The 04 and 09 have different mounting points for the exhaust, I don't think it will fit without modification
Also on the 08+ they had smaller valve stem diameters on either the exhaust or intakes(can't remember which ones though). The newer header won't work with the older muffler either, the older headers were long with a short mid pipe, the 06+ setup was a short header/longer midpipe. You could convert it to the newer system by switching out the subframe/airbox though. I think the linkages are the same.
