KX450 rekluse core exp?
I was taking my rekluse off of my 09 KX450(I was planning on getting a 12) and while removing the lock washer from the nut that holds the rekluse clutch backet the tabs broke off. I have removed it from my 09 and put it on my sons 2011 a few times for him to try and I guess in the process the tabs got weak.
My question is can i use the lock nut from the stock clutch basket or do I have to use the provided nut and lock washer with the rekluse core exp? Thanks in advance!
Sure does, thank you. Wonder why rekluse didn't just use the oem lock nut in the first place? Rather have a lock nut than a lock washer myself. Thanks again!
