will a 2004 yz 250 shock fit my 2000 yz 125?
not sure about the 2000 but heres some useful info on yz shocks
The wr -07 shock is 488,5mm 16mm shaft yz250f-06 is 488,5mm 18mm shaft yz250f-07 is 490mm 18 mm shaft wr/yz426-02 is 490,5 16mm shaft yz450f-03 490,5mm 16 shaft yz250f-02 490,5mm 16 shaft
looks like all those will interchange, you need to measure yours.
The clevis of a 05 shock is 5 mm longer than the 1999 one.
Dont no if it helps. You should check the YZ partlist for partnumbers perhabs.
