YZ85 Fork Oil Change
Looking to change fork oil in YZ85. My son weights 91 pounds and is a aggresive rider. What weight oil and how much do I want to put in. Also do you have to remove all the springs when adding and measuring the oil?
You can use any good q fork-oil
and yes you have to remove the springs completely to meassure
90mm is the highest recommended
Kim
Are you supposed to remove the rebound rod when measuring?   Reason I ask is because the manual says 320mL will give you a height of 3.54", but I am getting 2.4".
