A weird idle problem
So I have a feeling its just the idle(leak) jet being plugged...but.... heres the symptoms
The bike will ONLY idle when the idle screw is up really high and with super high RPMS.
Once i lower the idle down the bike dies right away, barely even bogs before it does.
The bike kicks over and starts SUPER easy with the throttle screw super high.
I imagine the idle jet is clogged, or wrong. Anyone else have any ideas?
Tear the carb apart, give it a thorough cleaning and replace the pilot jet. Adjust your idle ,ixture screw properly and go from there
could be a busted diaphram in the carburetor. I just bought an '01 WR250F that has the same problem. I tore apart the carb to inspect everything; the only thing I found was the accelerator pump diaphram disintigrated into pieces. Hopefully that cures the problem.
