07 crf450 supermoto 498 big bore jetting suggestions
Hi, I have a 2007 crf450 that is in supermoto trim and I'm looking for some suggestions on the jetting for an engine i just got done building.
Here's the list of the engine mods, carb specs and riding conditions.
07 crf450
engine mods
Hotcam stage 3 shimmed to .004 intake and .008 exhaust
ported head with stock size TI valves
Ice cube 498cc big bore
12.5.1 comp ratio
k&n filter with air box sides removed
full PC exhaust
vertex 10 position cdi
falicon crank
CARB
stock bore fcr41mm but im looking to get it taper bored to 43.5mm (suggestions on this)?
crfsonly fuel screw 1-3/4 out
main jet-178
pilot-42
needle- NJYR
clip- 3rd
leak jet-50
Riding conditions
altitude- 1800-4000
temp 60-90f
fuel-93 pump
supermoto style riding mostly street with track occasionally
Any suggestions on a good jetting baseline would be greatly appreciated!!
thanks,
Matthew
Big bore jetting is often leaner than standard bore. You should have been at a 162 main for 2,000 feet and above. You are drowning it in fuel right now. start with a 165 for the colder temps and see how it runs.
ok I orderd a 165 main from the stealership and it will be here in the morning. Is the NJYR needle a good needle to stick with and should i just leave it on the 3rd clip?
OK I put the 165 in and got the fuel screw 2 turns out and it runs like crap up top. Pulls good till around 7 or 8k rpm's and then it falls on its face, put the 178 back in and it fixed the top end but it doesn't sound as (crisp). Any ideas why it wants a fat main jet?
