Water pump leak? Gasket?
OK I notices a slow leak of coolant below the water pump housing. I checked the oil (changed it) no sign of fluid in the oil. Took off the impeller - it looks brand new, and the seal behind it looks perfect as well, and new to (bought the bike used, had been worked on by munns). so now all I can figure is the gasket is not sealing properly, but it looks intact and smooth. Bolts were snug as well. So what do you think? just replace the gasket? I'm up against it time wise, if my local dealer doesn't have the gasket - I am pretty much screwed for racing this weekend.
I may be wrong its been a long time ago.
When I did mine on my old Crs It would leak out the hole as you are saying.
But when I replaced the seals I also put in a new impeller.
On my old Crs the impeller always had a grove in it.
Edited by Ron731
