Breather hose fitting replacement
I'm talking about the 90 degree fitting which inserts into the valve cover on 07 TE's. I saw it a while ago (made of some metal), but forgot who makes them.
Zip Ty Racing I believe, but their website is currently down.
If it came loose or out and is not broken, Clean cover and fitting mix up some JB weld and stick it back together. Make sure you get the alignment right because once done won't come out or leak again.
If can't use stock clamp zip tie works fine screw type hose clamps tend to crush and distort it when it gets hot oil vapors going thru it.
Later George
