Seat
Hello a newbie here, just purchased a 96 xr250l.(no pics yet) Love the bike but I need to trace some wiring under the seat.
Dumb question but how do you remove the seat? Does the rear fender have to come off with it?
Remove bolt from each side raise slightly and pull seat toward back. You have alignment guide front bottom and at tank that must be ligned up when you reinstall.
Dunno if im getting blind but dont see any bolts anywhere to remove it. (have side panels off)
I have a 96 250L too!!!! just bought mine also! To remove the seat;
1. Side covers off
2. Remove the seat strap with 10mm socket
3. Look under the rear fender and inside it. You should see 2 identical bolts on the left and right (they might be a bit rusty)
4. use a 12mm socket and take those out
5. lift up on the back and push down on the front of the seat and then pull back it should come off
if you still have trouble PM me
