'08 OIL COMING OUT OF VENT
New issue: at the end of a ride, I notice the next day a small pool of oil that has come from the vent tube that snakes near the left side of the motor.
Oil quantity in the motor is correct.
What would cause this?
A clogged widgameedoo? Maybe the ferlapilator isn't working properly. First thing I'd check is your tire pressure.
Oil ring blow by? Done a leak down? How fresh are those rings?
Bad oil pump?
Is it a concerning amount?
Edited by Justin Hambleton
I switched oil from motul 5100 to a cheaper brand and I had same problem.When i switched back the problem want away..
The same thing happen if the oil pump is broken
could also be worn rings
or if you put to much oil in
Hope this helps
Ernie
Motor is fresh and tight. It's about 10cc of oil each ride.
Bad oil pump?
Ohhhh, didn't think of that.
HOSER
HOSER
All in good fun Krannie. My latter two thoughts were genuine. Can't think of any other reasons for increased crankcase and/or oil pressure.
OK then, MR Hoser then.
Yeah, it's a friggin Kawa. Seems to always be something illogical going on.....
There's a scavenge pump screen on the bottom to the motor. It's really hard to see, remove, and keep clean but if it gets clogged it can cause the oil to flow out the vent hose.
You mean the one behind the flywheel? Cleaned it already.
