2008-12 hammerhead shift lever
Bought a Hammerhead shift lever for my 2008 rmz 450. Just what the doctor order,I have a size 11 boot.Order the plus 10.
Have tried 05-07 rmz 450 shift lever sunline.Hammerhead shifter had no clearence problem with neutral switch cover bolt head.
Had issue with 05-07 sunline shiftlever hitting a neutral cover bolts.
i got the outlaw racing 2005-2007 RMZ450 shifter from pitposse for my 09. I had to file a little notch in the shifter to clearance the case bolt, but the bike shifted so much better.
if you want more room, you can get the new moose racing pegs, they have an option where the pegs are shifted 12mm further back.... in 2005, they improved the handling on the RM250 by modifiying the pegs so they were further back!!!
You can order Hammerhead shifter lever,from your friendly dealer thur Parts Unlimted.Its such a better product then 05-07 shift lever set-up,been down that road.
