Handlebar movement after installing risers
So I put some risers on my 250x and ever since then I cant stop my bars from moving. Clamps are tight but I can still push the bars forward and pull them backward. I do have oversize Renthal bars with Renthal clamps and Tusk risers. Anybody got any ideas how I can remedy this?
sound like you have a bad part somewhere. if you have a caliper and check the diameter of the bars will tell you if its the bars or the clamps
and there is a torqueing procedure for the handle bar mounting caps. the two foreward bolts get tightend down first flush with the lower bar holders. then you torque the backs, and there should be a small gap that can be seen between the upper and lower clamps on the back of the holders. if you dont have that gap and there both flush, you have a bad part somewhere.
