Will the Moose Eline Exhaust KX Guard Fit KLX450R?
I am looking to buy the:
Moose Racing Eline Exhaust Guard for the FMF PowerBomb headers.
I currently have the KLX450R powerbomb, and the moose fitment chart says
it will fit the KX450F 09 power bomb header.
Are they that different? could this fit?
Thanks guys!
You will need an e-line guard to fit the 06-08 KX...the mounts are different from the 06-08 models and the 09 models.
Thanks for the reply!
I was hoping seeing as the E line guard mounts using clamps around the header it's self it might just mount up. Alas!
I will keep an eye out for the years you posted, thanks again!
It might fit...espectially as it is only a clamp mounted guard and does not have to line up bolt holes and only needs to follow the lines/contour of the pipe...might be worth a gamble but check the availability of an 06-08 first. Good luck either way
